PaulMarcel
I missed this thread when it was lit... I'd just like to add an anecdote. I received the GRS-16 PE Parallel Edge Guide Rail Square and decided to play with it a little bit. Popped it on a board, crosscut, then checked square. hmm was a hair off (wait until the end...) enough that it would be a deal-breaker for any cross-cuts over, literally, 2 inches. Checked and checked again; it seemed perfect but why was the square saying it was off? Well, did the "two-line" test on the square and the square wasn't. Grabbed a square I trust for checking the others and sure enough, it was dead square. So if you want a guide that can crosscut and verify your square, this is the one. I've actually tested a couple of other crosscut guide attachments (some that went to market, some that didn't) and this is by far the easiest to use and, anecdotally, the most accurate with little effort.
Highly recommended.
Highly recommended.
