Which size Incra T Track for the Senaca Parallel Guide
Nash
Im debating which size incra t tracks to purchase to go alongside the Senaca parallel guide system. I will mostly be cutting and ripping sheet goods but there is always the possibility of cutting smaller size material. Does anyone have an opinion which track would be the most versitile?
Thanks Paul G. Do you have a preference or is there a set you use more than the other.
Just depends on what I'm cutting, using the 4' track on small pieces gets a little cumbursome for me so thats when the 2' gets used. Your mileage may vary of course. Easy to switch the tracks when needed.
