I need to make some 2 m long straight cuts in a fiberglass panel approximately 6 mm thick. I only have a few cuts to make but would consider a new blade to keep for future uses.
theres a plastics and laminate blade. it's like 36 teeth with rounded tips. i got one to use for pvc. any blade will cut that stuff. i would slow the speed on the saw to reduce any chance of melting. start slow and work your way up if it's to slow.
