Will C12 chucks and battery charger work with the CXS??
woodwreck
That says it all - on buying a new CXS, will I be able to use the items from the C12?
TIA
The CXS has a different charger and battery format than the C/T-series drills. So, you will need to use the CXS charger.
Edit: I should mention that the CXS comes with a charger and can't be purchased without one.
You can use the Centrotec and keyless chucks from the C-drill, but not the eccentric or right angle. This really doesn't get you much over the CXS as it's sold, except slightly more capacity in the keyless chuck (1/2" versus the 5/16" with the CXS).
Shane
GhostFist said:
So in a word, no.
But sort of.
I have swapped the cetrotec chucks back and forth and used the keyless chuck from my c-12 on my cxs.
I did manage to mix a small batch of self leveler, mortar and some dry wall mud with the little guy.
The cxs kind of surprises most times I use it.  I have hated every single compact drill I have ever owned or used.
I think I might like the cxs. [scratch chin]
