Mike Goetzke
- Jul 12, 2008
I bought some fence planks at HD for an outdoor project. They are called Alta Premium treated - think they are hemfir/spruce.
When crosscutting I'm getting a little burning like you get with a dull blade. I could feel more resistance as the blade was fully engaged in the middle of the board. This is a new Makita cordless with not much mileage on the blade (although I did just finish several cuts on some MDF). I did try to measure the toe-in. This is difficult but results did show recommended value. I found the saw was little loose on the track so I adjusted that and only made couple cut but seemed better.
So, I'm thinking the burn is most likely dull blade, bad toe-in, or loose fit on the track. Any experience to help me diagnose this appreciated.
Mike
Mike
