- Jan 22, 2007
Conventional framing squares may be OK for construction jobs where “square” means in the neighborhood of 90°. That’s what you can expect from a square that’s punched out by the thousands or molded out of plastic. As most woodworkers know, framing squares simply can’t be trusted in tight tolerance shop work and can be difficult to use.
A Square So Good Its Guaranteed! Woodpeckers new, large-sized Precision Framing Squares offer accuracy that’s so good, it’s guaranteed. How precise? Our squares are machined and quality checked to be dead square within .0085 degrees or better. That amounts to about .001" per foot.
Available in two sizes, imperial or metric scales, with or without a case. Or, go all in and get both sizes in a set to save.
Order deadline March 5th, 2018.
Buy Woodpeckers' OneTIME Tools
