Woodpeckers OneTIME Tool Step Gauge Set (US)
Shane Holland
Festool Dealer
When was the last time you set a router bit or table saw depth of cut and got it perfect the first time? No one has that much luck! Using Step Gauge RTS, guesswork flies out the window. To get the perfect setting, simply position the gauge over the bit or blade with your desired dimension at the corresponding step. Now you can make the setting adjustment with both hands free thanks to the gauges' supports.
Order deadline is July 31st.
Order Woodpeckers OneTIME Tool Step Gauges
