- Sep 21, 2022
Woodpecker's latest OneTIME Tool release is the Posi-Lock T-Square family. These T-squares feature a protractor head that adjusts +/- 70 degrees, with positive stops at every 5 degrees as well as 22.5 and 67.5 degrees. With the Posi-Lock T-Square, you can confidently create accurate layouts of large or small workpieces.
The stainless steel blade is sturdy enough to prevent deflection, yet thin enough to avoid parallax. The blade is laser engraved in 1/32 inch increments with a tolerance of +/-0.004 inches total accumulated error, while the satin finish reduces glare. Lastly, Woodpeckers' scribing notches allow parallel layouts in 1/16 inch increments.
T-Squares are available in 12, 24, and 32 inch lengths, as well as a set of all three. Each includes a wall-mount Rack-it.
Click here to check them out. Order deadline is November 6th at noon.
