joiner1970
- Jun 13, 2007
I'm thinking of building some down draught extraction for the contractor style table saw. I want to use my ts55 to build the funnel part out of MDF. Is there an easy way to work out the angles I need to cut the four triangles at. Hope this makes sense , so if the base was flat then the four triangles would be 45 degrees with 90 degree edges. Then as you raise the edges up to form a funnel how does the bevel cut change in conjunction with the angle of the triangle.
I know I could mess about with trial and error but would like to do it right . I probably was taught how to do it at college but its been awhile
