C Cellule Member Joined Jul 30, 2013 Messages 54 Jul 7, 2014 #1 I broke the drill bit that goes to the zobo set. Is there a remplacable bit or like the zobo I need to buy another set to have the bit? Or is that a common size of bit?
tbellemare Honorary Member Member Joined Nov 3, 2007 Messages 5,092 Jul 7, 2014 #2 It's a 2.5mm brad point bit. It can be found multiple places. Festool will also sell the kit that comes with the set that has all of the tips and the pry bar for $25. Tom
R Roseland Member Joined Aug 16, 2009 Messages 676 Jul 8, 2014 #3 Tom Bellemare said: It's a 2.5mm brad point bit. It can be found multiple places. Festool will also sell the kit that comes with the set that has all of the tips and the pry bar for $25. Tom Click to expand... On my set the drill shank and pins are tapered, I think. I imagine a parallel shanked drill would wobble and fall out! Andrew
tbellemare Honorary Member Member Joined Nov 3, 2007 Messages 5,092 Jul 8, 2014 #4 You are correct, Andrew! It appears to taper down about .15mm in diameter down to about 2mm at the end. Tom
