HowardH Member Joined Jan 23, 2007 Messages 1,579 Location Albuquerque Jan 27, 2021 #1 Will a 125 pad interchange on the 150 sander? I want to put some 125 polishing sponges on it.
Jim_in_PA Member Joined Nov 23, 2017 Messages 595 Jan 27, 2021 #2 Unfortunately, no. There's no compatibility in that direction.
HowardH Member Joined Jan 23, 2007 Messages 1,579 Location Albuquerque Jan 27, 2021 #3 I figured as much. That way you need to have one of each!
Cheese Member Joined Jan 16, 2015 Messages 12,955 Location Land of 11,842 Lakes Jan 27, 2021 #4 No swap ability on the RO front...only on the ETS EC front. [smile]
AlexThePalex Member Joined Nov 12, 2008 Messages 7,757 Jan 27, 2021 #5 What's keeping you from cutting a 150 pad down to 125? [wink] Though it might be easier to simply use 150 mm sponges on it.
HowardH Member Joined Jan 23, 2007 Messages 1,579 Location Albuquerque Jan 27, 2021 #6 for aftermarket accessories, pads, etc., there is a much better variety of 125mm pads vs. 150. Seemed like it could be an easy fix.
Bertotti Member Joined Oct 18, 2020 Messages 382 Location SD Jan 27, 2021 #7 I think I would just cut down an older 150 mm disc then use the 125 mm pads on it.
flair woodworks Festool Dealer Member Joined Nov 18, 2010 Messages 1,023 Jan 28, 2021 #8 HowardH said: Will a 125 pad interchange on the 150 sander? I want to put some 125 polishing sponges on it. Click to expand... Unless you are polishing into corners, just put the 125mm sponges in the 150mm pad. I don’t think cutting down a pad is a very good idea.
R rvieceli Member Joined Feb 4, 2008 Messages 2,427 Location Carbondale Illinois Jan 28, 2021 #9 [member=396]HowardH[/member] Try this vendor. there are a lot pads [eek] 6.5 inch for 6 inch backer plate https://www.autopia-carcare.com/buffing-polishing-pads.html 25% off coupon ends TODAY at 11:59 am EST free shipping on $95 plus Ron
