I am knocking around the idea of purchasing the 1400 router. My most immediate use for the tool would be dadoes for shelving something like a bookcase. I currently use a 690 with a fractional base and a shoot board. I run either a 1/2" or 5/8" dado and then rabbet the shelf to fit a bit loose in the groove. The advantage of this system is that the edge of my shoot is the edge of my dado which I find helps me to avoid many stupid measuring mistakes.
I am wondering if the router can be adjusted over so that the edge of the bit kisses the edge of the guide rail. I saw John Lucas do something like this with the smaller router, but said that he had to rig the guide from other parts. He did not elaborate as which parts and how to combine them. I asked the same question of the guys at my local Woodcraft, but they were unable to answer. If it is not possible how do you gentleman set up for cuts of this nature?
I am fairly new to the Festool system so I beg your pardon if this is a silly question.
My thanks in advance,
Justin
Justin
