Cheese
Thanks for the heads-up Ron...
anthonyz said:Cheese said:Fantastic...I really appreciate the info from both of you. [thumbs up]
I really need to do some research into this further. Thanks for the references.
I did read a few days ago that 3D printing was now available for use with aluminum. Again, I placed this within the reference frame that I was familiar with which was the $20K number. Thus I dismissed it. I'd be willing to spend up to $5K for some CNC/3D printing hardware. I think I'd like the CNC platform to be a bit larger than the 3D platform.
If you are tech savvy, look at the X-Carve cnc, if you are up for a weekend build. Very affordable and can be expanded, then look at the 3D printers for a good starting place. If both are in the same unit you will only be able to do one thing at one time, and then the break down and set up between each becomes another whole factor.
https://www.inventables.com/technologies/x-carve
jbasen said:anthonyz said:Cheese said:Fantastic...I really appreciate the info from both of you. [thumbs up]
Next Wave Automation made going between CNC, laser, and 3D printing very easy. Each device has the same form factor as the Dewalt router that is used for the CNC router function. So, all you do, for example, is loosen the bolt for the router clamp, slide out the router, slide in the laser engraving head, tighten the bolt, plug the wiring connector into the controller, and you are ready to go. Pretty much the same for the 3D printer head.
I have a small shop. Having separate devices for routing, printing, and laser engraving would never work for me. Also, as a hobbyist, the time to switch functions or not being able to do two jobs at once isn't an issue either.
Personally, I can't see anyone in this group going into the business of producing 3D printed objects on their own. A printing company, like shapeways would be a much better approach. Take your design and let somebody with much higher quality equipment than is affordable for an individual do the actual printing.
bkharman said:On another note... Don't you love the way the 130 works? About 5 minute learning curve and that thing is your best friend for that project. Doesn't always have its place but when it does, man it does awesome!
I have had mine for about 2 years now... Love it!
Cheers. Bryan.
anthonyz said:jbasen said:anthonyz said:Cheese said:Fantastic...I really appreciate the info from both of you. [thumbs up]
Yes, but Shapeways is expensive depending on what you are making. For making the clip backer plate for the LS130 it cost me about $1.50, on Shapeways it's closer to $20 and if you want a little royalty for your work then it jumps from there. And if you have to figure out a part, then the wait time between each get to be a hassle. But if you are just printing a 1 off of something that had been prototyped to make sure all the bugs are worked out, then it works.
Gjarman12 said:[member=34574]anthonyz[/member] How big of a surface do you need to print the generic base for the LS130 to make your own pads? Being able to do this might push me over the fence on the sander.
Gjarman12 said:[member=34574]anthonyz[/member] THANKS. Where do you get your foam, and has the Velcro held up so far?
