Hello all,
I have a 75 eq and I am currently have troubles with the front Jaw Guide staying put. Before a cut i adjust the front a rear guide to eliminate all the play. At times I can only go about four feet before the front Jaw Guide gets so tight on the track that i can not move the saw. Just yesterday i was cutting 2" thick walnut slabs and on every cut i would get roughly half through and then i would have to stop readjust the guide to finish my cut. As you can imagine the quality of the of cut is far from being desirable. If any one as any ideas please pass them along. Also I am certain the front jaw guide is moving i put a witness line on Jaw Guide and it moved roughly one half of a revolution and then go so tight i could not cut any further.
Thanks for the heko.
