Accuracy - How accurate and how difficult?
In terms of accuracy, how accurate is the saw? (i.e. - 1/64", 1/32")
How easy is it to get it accurate?
Chuck
Hi Charles,
There have been several threads on this topic.  The good news is that the saw can easily and reliably deliver accuracy to 1/64 if that's your standard.  If you are using the guide rail without the table, then the limiting factor is your ability to mark accurately and your patience with lining the guide rail up to the mark.  If you are using the table, the key factor is taking the time when you first set up the table to calibrate the fence and the guide rail holders to be dead square.  If you are making several pieces, clamp a stop to the table to ensure repeatability.
Charles, It's all about precision!  I will trust a freshly cut splinter-guard on the FS rails as much as I would trust my finely tuned Unisaw.  Festool is all about precision and ease of use.  It is just like everything else though; it's all about the set up for the cut.  If you want precision, you have to take time to ensure the human factor is covered.  The mechanics with Festool are first rate!
Timmy C
Charles,
I second what was already said. Setup is the key. I routinely cut to 1/32 with guide rail and clamps with no problems. Save the occasional error on MY part. Old eyes and all that stuff.
Hi, Charles
      If you measure and mark accurately, paying attention to use the same technique when marking and aligning. Then it is a very accurate saw. I would say that 1/64" repeatability is no problem.  You  can make it easier and more repeatable even with out the MFT by using a jig (one was just shown in another thread). Or some type of system for setting the rail.  Your goal for getting the most accuracy is to elimenate human error. The saw itself is very accurate.
      I like to reduce  the human error by using some of the Incra and Woodpeckers measuring/marking tools combined with John Lucas's razor blade alignment idea.  The Woodpeckers T Squares have pencil point size holes every 1/16" , and the Incra rules are similar.  If you put the pencil in the correct hole  it is very hard to  be off the mark.  Then tap in a razor blade on the mark. Push the guide rail up against the  razor blade, and bingo the rail is right were it belongs. It is really easy when using the thin edge of a razor blade to place the rail in the center of the mark or on the left / right edge of the mark.  This may sound like a bit of a process but it is actually very fast, and saves time.
