One of the odd things in my life is, that sometimes when I need something, I just get "provided" out of the blue, at precisely the right time.
So this happened once again. This time with the plinths. I had calculated what I needed a few months ago and asked my lumber yard for a quote. 150 euros for the entire first floor, which needed 42 meters. I didn't like that quote for just a bit of MDF/HDF.
And whadda ya think? I just finished all the walls and was in need of them now. So I find them on the street. I am not above a bit of scavenging when it saves me a few bucks.
Apparently somebody just installed a new laminate floor and threw all the old stuff out. Including all their plinths. Which were all oversized for my use, but that's no problem if you have a CS70.
So out goes the CS70, extension table installed, but still not long enough for these plinths.
That standard angle fence does look awfully small now. It didn't really work, time to get out the longer CS70 LA for this.
Oh, I made a mess out of it again. I do get tired sometimes of hauling the Midi+cyclone around all the time.
But all oversized pieces are down now to the 9 x 140 mm I want. Unfortunately one long one had a crack and broke in two. Another one was a bit wet so I had to let that one dry first.
All done now, sanded to 400 and very smooth, and a small 2 mm roundover to break the edge.
OK, I found some more in the same spot. Kewl.
So out with the 70 again. These were not as long as the others though.
And all done again, sanded and rounded over. Ready for priming. Saved me 150 bucks, and cost me 3 hours works for sawing and sanding. And now I surely have enough for the entire floor.
