Lots of folks have been wishing for an inexpensive alternative to expensive Festool circular saw blades. And after cutting many sheets of construction ply (1 1/8" thick) and dulling my Festool blade, I was looking too. Yea, I know...I could just use another "regular" circular saw. But I really like the TS75 and use it exclusively for any type of sheet goods (including construction ply). Nothing available, so I developed my own solution.
I got a tremendous deal on a bunch of 16t Freud Framing blades a few months ago on Amazon (i.e. $4.18 each delivered) so I decided to try out my method on these.
#1) Drill two 3/8" holes in the blade directly opposite each other to line up with the threaded holes in my friend's metal lathe faceplate.
#2) Using 1/4" cap screws, secure the blade to the faceplate LOOSELY.
#3) Bring up the tailstock with a cone center to center the blade on the faceplate referencing off the original 5/8" center hole.
#4) Tighten up the two cap screws securing the blade tightly to the faceplate.
#5) Twist out the diamond knockout.
#6) Using a carbide tipped boring bar, enlarge the center hole to 30mm.
#7) Deburr and dismount from lathe.
#8) Mount on saw and test.
There is a difference in the cut line from the original Festool blade, but that's what replaceable splinter guards are for. The only problem I found so far is the kerf is smaller with this blade, so the riving knife binds. Haven't figured that one out yet...
