You don't get any binding, at least not enough to worry about. On a 2440mm sheet, with a 3mm kerf, and maybe a segment of the blade about 150 mm long doing the cut, the cut will only start to close up when you get near the end of the cut, and it can't close up much - with the figures above it will only be approx (3*150)/2440 - less than 0.2mm until the point where the cut breaks through the end of the board. I had some shuttering ply cut today on a vertical panel saw, and I couldn't detect any sign of binding or innacuracy by eye.NYC Tiny Shop said:Jalvis, can this be bought in the states and do your know how much? Also, there must be a way to toogle clamp the piece from above, to keep gravity from causing any binding? I didn't see any binding in the video. Is there something in this set-up that prevents binding from occuring? Questions, questions.
Peter Halle said:I suppose there are different definitions of what makes up a real panel saw. Safety Saw Cut and other manufacturers offer panel saws that are calibrated to within 1/32" at starting prices less than 5K with a saw and a router, or considerably less without a router. You can go upwards from there. Comparing a 50K panel saw to a 1K rail saw setup better show a payback or else it is a waste of money.
Jalvis said:I'm perplexed by some of the comments.
Building a business with a Track Saw is one very hard task. Good luck making more than a wage.
The saw in the video is also a low cost option and I can say that not knowing the price. Real panel saws start in the 10k-50k range and that saw is not one to be sure.
As for dust collection on a Vertical Panel Saw my experience is in the 90% and thats with a low cost dust collector.
