GoingMyWay said:Here's the video that was embedded in the previous
The full URL (youtube.com) and not the shortened URL (youtu.be) needs to be used in order for the video to load properly on the forum.
Packard said:It works just like the Beadlock jig, which is to say it is tedious.
Also, conventional drill bits do not like to break into the adjacent hole. That angle lead-in causes the drill bit to veer of to the side. Because of that I would drill the outside holes (the ones at the far right and far left) first to avoid a sloppy fit.
And note that conventional drill bits do not perform well as milling bits, so the horizontal movement will not go as easily as shown.
The beadlock system avoids that by requiring special shaped tenons, which you can buy or make in your shop.
If I were to invest in a tedious joinery method today, I would go with Rockler’s $99.00 beadlock over the equally tedious Jesse, version for $400.00
4nthony said:
Michael Kellough said:Packard said:It works just like the Beadlock jig, which is to say it is tedious.
Looks like it is an end mill bit.
