Another take on systainer storage
mwolczko
San Carlos, CA, USA
Here are a few photos of a systainer storage cabinet I just finished. It's a bit different in that each shelf holds two systainers. I was constrained to accessing both from the same side, so set them on 26x16 ½" plywood shelves using 26" slides with an inch of over-travel. The over-travel and a gap between the systainers means each can be fully opened in place. Each shelf has indents routed to match the systainer's feet, to stop them from sliding around. I made a template for routing the indents, which also served as a mask when spraying them (just to hide their plywood ugliness). The indent shape accommodates both T-Loc and classic systainers.
-Mario
Excellent job. Can’t really tell but I’m assuming the label on the pull out identifies which sustainer is behind the front one? Also curious what type of slides you used
