[attachimg=#]
Lots of storage space in each room.
[attachimg=#]
Coat locker in each room opposite the storage/shelving area.
[attachimg=#]
Coat locker door.
[attachimg=#]
A bit of explanation on why these rooms are constructed the way they are: each stateroom that I rebuilt has a tonnage access door that houses the portlight. It's necessary for these access doors (basically a steel panel in the bulkhead) to be able to be removed, along with the bunks, in order to replace large items in the house (refrigerator, washer/dryer, etc) which can't make it through the passageway doors. Hence all the exposed stainless steel fasteners instead of plugged holes, etc.
If I were to do this again I would build things a bit differently but I think that's the case on most jobs...
The doors to the staterooms had to be set in a panel that could be removed as one piece (including threshold, door, etc). This was accomplished with some angle iron and threaded rod with a bent end which I'll show in the next post...
[attachimg=#]
[attachimg=#]
Coat locker door.
[attachimg=#]
