Richard/RMW said:
I just picked up this
kit myself, primarily to mill aluminum plates and small blocks of plastic for my various gadgets. Already assembled it and tested with a grbl based controller, only too 5-6 hours to get from unboxing to motors moving. It is more in league with the X-Carve also but has what I believe an upgrade in that it uses acme screws rather than the GT3 timing belt for the linear motion. Its small form factor & design is also a bit more rigid which should provide better precision when milling AL.
That looks like a decent machine Richard. What always kills me on the small ones is that for guitar parts (neck carving especially) I just need a bigger cutting area. Over 24" in once direction fit a neck on it's long axis.
I was tempted to piece together a small one with an elongated axis, but was afraid that once I got going, I'd find other uses for it (which I have just thinking about it). So I ended up with that 4x2 which meets the needs for guitars and than can be (relatively) easily expanded to 4 or 8 feet later if I decide to do that.
For reference, here are the justification use cases I came up with for my shop (that and an $1100 bill on my last trip to the CNC service, which made me realize pretty soon I'd have paid for my own machine).
Lutherie
Brace profiling
CNC jigs for holding braces and cutting on both sides
can make bridge trusses”, cut outs to reduce weight
Bridges
headblocks
machining for carbon fiber axial brace
tailblocks
bending forms
body molds
neck building
neck holding vacuum jig
carbon fiber inlay
neck profiling
Templates
headstock
Body shapes
drilling template for heel bock (or CNC machine the holes prior to heel attachment)
fretboard Inlays
headstock inlays
back and top cutouts
rosette inlay
cutaway blocking
beveled armrest blocking
heel hardware? Aluminum?
back tapering jig
15’ convex form with body shape cutout for precise marking
Boatbuilding:
ribs
canoe forms
Jigs
jig parts
