tomsharres
- Aug 2, 2014
I worked with an importer in Portland, OR and had a 4 axis router built to spec.
5 x 10 foot travel, 5 x 7 1/2 vacuum table, cut out well for 4 axis on one end of the table, and support for vertical work from the surface to the shop floor. The vacuum pump is a dry vane style, and all the drives any Yaskawa servo's.
I wanted to be able to use a 5 x 5 baltic birch panel, and also to carve a full height exterior door.
I've attached a couple of photos. It's not hooked up yet.
That other gizmo is a 20 inch Felder jointer, also not hooked up yet.[attachimg=1][attachimg=2]
UPDATE:
Since I posted, I've ordered a Felder RL 200 dust extractor, and conveniently, my neighbor is moving out so I'm going to add another 1500 sq foot unit adjacent (a demising wall separates them) to my existing shop. This will alleviate an issue with power in the current shop, and also is big enough so that I can keep all of may current and future woodworking equipment is a single environment for ease of dust control. I'll update in November once the RL 200 arrives and everything is operational. The router will no longer have such limited access as it does now.
UPDATE:
