Richard/RMW said:FWIW - when I replace the splinter strips on my rails I take a minute to abrade the AL with some fine grit paper after cleaning it with lacquer thinner, then clean it again after sanding. I don't think any of the replaced strips have come off the way the factory installed ones to. Have to check this to verify my impressions though. YMMV
RMW
Agree on this. The replacement Festool cutting strips are nowhere near as adhesive as the factory installed ones. It's probably a combination of the age of the strips and that they are distributed coiled up. I have tried every trick to get the replacements to stay with the only fix being to do exactly this. I'd also recommend laying the strip out for a few days to make sure it is good and flat. A hairdryer can help with the flattening process. The Mafell design is substantially better as is their rail connector.
