Michael_MA
- Jun 14, 2009
jmbfestool said:[attachimg=#]
great sketches JMB, but i have to admit, the technology of the devices is more advanced, than we may expect..
It's true - Example 2+3 will cause GIGO for all Devices below the leica D8, which only has a problem with Example 2 - the curved wall.
All others will create perfect results, as the D8 contains an 360 degree tillt sensor, thus not requiring right angle reference measurements.
The D5 provides reliable results for Example 1 and 4, as the built in +/- 45 degree tilt sensor provides reference for the measured angle. up and down to level.
But to be honest, if you have a wall like Example 2 (curved) , you simply would not use any straight measurement method.. cause either line or laser will cause lase results..
So a ladder and a tape measure with some artistic would be required there
kind regards, Mike
