Are Festool power tools as tough as we claim?
  • Thread starter Thread starter Administrator_JSVN
  • Start date Start date
I'd like to see how a T15(or C15) could handle mixing a 5 gal bucket of drywall mud with a large mixing paddle (1/2" chuck").  That would impress me.
His drywall compound looked a bit loose.
Drop that thing in a 5 gal bucket with properly mixed modified thinset, then test it!
Has anyone used their Festool drill to mix a bucket of thinset?  That's a test!
I had tried my old C12 with 3ah NiMH battery with a professional 4 blade drywall mixer with a 5 gallon bucket loaded about half way with setting compound and different amounts of water as I did the mix.  It has a 1/2" shaft.  Got a lot of beeping so I switched to my Makita electric D-handle with side handle to git R done.  Also found it a little tricky without a side handle on my Festool drill from the torque reaction.
i dont think any battery drill would stand up to that sort of mixing.  if the festool drill will stand up to tile adhesive i think they should try that compound for sticking insulated plaster slabs, that stuff is serious tack [scared]
Alan,
This was before I had gotten my 18v Milwaukee tools.  I've used them with the side handle to do mixes just fine.  Maybe the newer Festool drills and the upcoming ones won't have the same problem as my C12 did.
we use a skim coat (drywall) whisk in an old drill that my father has for years for the job. it is an old wolfe drill. we have is on the slower speed as the top speed would send the skim all over the room  [eek]. when we mix the insulated slab sticking compound you can hear that very powerfull drill slow down and the noise lever will change as it struggles to mix the stuff. this stuff is way thicker than tile adhesive
