Assistance with flush trimming solid edging with QF1400 Router.
Stephen B
[size=12pt]
I have some Mountain Ash solid edging on ply. I have a trimming router bit and a QF1400 but no edging plate etc.,.
Interested in safe techniques/ideas available only with these resources.
Thanks.
Bolt a block of wood to 1/2 of the baseplate→cover only 1/2 of the bit→set router on flat surface→plunge through block until bit just kisses surface→this should give you a zero clearance hand held milling machine.
Like this, but you need to install a block to achieve the offset base.
Or a bearing guided flush trim bit.
Couple of photos of the vertical offset base on a Porter Cable router.
