tjbnwi
- May 12, 2008
Drich said:My problem is the door sticks out to far due to the hinge plate that I mounted 37mm from the edge. As you can see in the picture I line up the cups and the one hinge is longer which pushes out the door. I'm thinking it needs like a 46 mm set back.
I see no picture of the hinge mount/door mounted on the case.
