poeterdebier
- Aug 24, 2020
Hello Guys,
I have two broken capacitors broken inside the electronic part of my CTL 26. So instead of buying a new electronic for about €130,- I will first try to replace the capacitors. Because of the black putty, I could not read the correct data from the capacitors. I think they are:
400 V and 4.7 uF. These are the only values that are compatible with the size (diameter and length) when looking up the specs from Samwha.
Now my question is: can somebody confirm these specs (4.7 uF and 400 V)? I just want to make sure before I put in capacitors with the wrong rating.
Thanks in advance,
regards Piet
Thanks in advance,
regards Piet
