Kodi Crescent
- Aug 6, 2010
I'm making a second attempt at building some frameless cabinets for a home office. My first attempt used 18mm Baltic Birch from a local "open air", but covered lumberyard. After building the carcasses, I could not get them fully squared, as the bit of warp pulled things the gables out of square. Trying to install them was a nightmare, so I gave up and decided to try again.
This time I used 3/4" MDF faced Garnica from a local supplier that stored the sheets in a temperature controlled warehouse. The sheets were nice and flat when I broke them down. Now having spent some time in the humidity of my garage, they have a bit of warp to them - in some cases worse than previously.
I'm assuming there is no way to really prevent the humidity warping in a practical shop application unless the shop has an HVAC system. How do those of you in high humidity areas deal with the warp and continue with the build?
