Bob Marino
- Jan 16, 2007
Bob
What is realy cool about your wager is this is actually fairly easy to test [blink] (with about $700 worth of montitoring equipmnet that i will be buying in the next few months) I learned all about OSHA air testing protocals for derermining respotory hasards and the proper level PPE (read NIOSH rated resporators) I am guessing that it it the tool selection and process rather than the vac that will show the issues. lets say an ets 150 /3 with 400 brillant on oak for 45 min. weigh the test block before and then after the ct test with a breather and test cassette ( this is an air pump that sucks at a given rate that you wear. with a tube and test Cassette (filter) that you clip to your collar "breathing space" . run it again with the mini weighing the block and making sure the sander is removing a statistically similar amount in the same time. send both test cassettes to a lab and see if there is a difference in the oak particle count.
Craig
Craig,
I agree that it would be an easy test to perform and also that technique may have more to do with actual inhalation of dust than what level of filtration the person is using. There are just a lot of variables in the shop enviorment that figure into the dust inhalation mix - level of vac suction, type of paper and/or material being sanded/routed/planed/sawn, amount of time the sander is overlapping the material, etc. etc.
Bob
