tjbnwi
- May 12, 2008
tjbnwi said:
tjbnwi said:Cheese said:tjbnwi said:I'll mention again, whatever you decided shoot only waterborne products. You're not set up for solvents.
I assume you're concerned with the explosion risk?
Yes.
Rick Christopherson said:tjbnwi said:Cheese said:tjbnwi said:I'll mention again, whatever you decided shoot only waterborne products. You're not set up for solvents.
Yes.
The Lower Explosive Limit (LEL) of lacquer is higher than the IDLH (Immediately Dangerous to Life and Health).
In other words, if you are going to have an explosion, you won't care about it, because you will already be dead. If you don't believe that, go look up the numbers on the MSDS sheets.
Rick Christopherson said:Tom, if you're going to advise people on this, you really need to increase your information sources. The OSHA PEL for lacquer is about 150ppm. The LD50 (Lethal Dose) is about 2000 ppm. The LEL is about 20,000 to 120,000 ppm. You are wearing a non-fit-tested APR, which will have a protection factor well below 5 (10 if fit tested).
The bottom line is that if you have personnel in the room, they will be long dead before you reach even the bottom LEL concentration. The concentration passing through your fan will be no higher than the ambient level in the room, and most likely lower due to speed and mixing. Additionally, most window fans are induction. They don't make sparks.
The situation could be different if you are using a small vent-hood type spray booth, where the operator is outside the spray cabinet.
Interesting, why the 15-25 AAA and not the new 10:1?brewster201 said:Just adding my 2 cents, I recently switched over from a Fuji 4 stage/pressure pot setup to Kremlin 15-25 AAA pump.
brewster201 said:The time you purchase a Fuji 5 stage, T-70 gun hoses, pressure pot you could buy a decent AAA pump for not much more.
Just a thought to ponder.![]()
brewster201 said:I'm not sure if your responding to me lol
You sell truck accessories!
These forums are here to share ideas and have good conversation
I'm fortunate to have years of experience with HVLP and decided move to a better system. I have sprayed around 40 Kitchens and too many cabinets
I'm trying to make my jobs better and easier on my myself. I retired 4 years ago after 37 years in the oil gas industry, power house, operation and maintenance.
Was involved in refinery grass-root startups, HP Boiler operation, Co-gen and water treatment plants.
I'm now happy to be involved in my passion
My pump setup is positioned outside my 8x10 spraybooth and have been using a 50 door vertical door rack
This is not a hobby but a business
The Kremlin system is not rocket science!
Bruce
My post was in response to the stated topic of this thread : "can a hobbyist spray . . ."brewster201 said:I'm not sure if your responding to me lol
Bruce
brewster201 said:I'm trying to make my jobs better and easier on my myself. I retired 4 years ago after 37 years in the oil gas industry, power house, operation and maintenance.
brewster201 said:Sorry Hans but you came off as very condesending and really not very helpfull!!
One should not highlight there product info/TSO(retailer) in these forums!
Who cares!
Bruce
