Can the new Impact Driver TID 18 be used to loosen wheel lugs?
So some more feedback on this
I've been using my TID 18 for wheel maintenance (wheels rotations, brake works...) and I must say I'm happy with the result
Not once has to TID struggled to break a nut loose (I work on properly torqued nuts so I can't comment if it could loosen a nut that had been over torqued to 500N.m by an idiot at the auto shop -yes, they are many).
Quite conveniently, the lowest level will torque to less than 50N.m no matter how long it is applied. That is quite a good thing for fastening : I bolt the nuts back with the TID on low, then finish them up with a torque wrench.
FYI second setting is above my target torque so I'm not using it for fastening.
