Cantilever Cabinet Installations and Water Line Nightmares
sandy said:
After a few waterline / electrical wire close calls, I now only cut through dry wall using my Fein Multimaster with a straight blade which allows me to cut straight in, rather than "sawing" through the drywall.  That way the depth of cut is only the thickness of the drywall. Also, I make a small opening, and then look inside with a flashlight and mirror to make sure I know where the lines, studs, and fire stops are located.  I have lots of Festools, but for the initial cut into drywall with unknown interior, I only use the Fein.
Ditto!
Used my fein...but the water line was pressing up against the backside of the Sheetrock! It was such a rats nest they couldn't secure the lines away from the wall.
Jon
Tube on one side of the wall and a vanity on the other.  A Pex and PVC nightmare.  Back to back plumbing walls are cost effective but tricky.
I like to tap through the drywall with a small rounded nail and identify both sides of every stud.  Does that make sense?
Jon
Sounds like you had a Fein mess there... Too bad...
