jmbfestool
		decoy said:I haven't experienced any of the mentioned problems with my Carvex (ps400), but am I the only one who finds the autospeed-function kinda annoying for precision work? It slows down so much that the vacuum has trouble removing the MDF dust, making it hard to see where I cut. I'm not 100% sure how Carvex-speed is connected to dust extraction, but the visibility does get worse when I slow down :-/
Also, the top-speed on auto seems to be higher than the top-speed I can set manually?
Yes thats true! I noticed that when you set the manual at the highest its no where near as fast as when its on auto! I dont know why that is. I think it should have a second auto! Auto on/off! Soon as you put pressure it slowly turns on to full speed and when you stop after 1 second it turns off. Its because I still have not go use to using barrel grip jigsaws. I can not see how people think barrel grip you have more control than D handle. With D handle you can slowly pull the trigger to gradually increase the speed to full and then stop straight away by releasing the trigger. I often have to reach for the off switch on the Carvex barrel grip so it takes my attention away from the blade cutting the material. Its okay if your cutting material off its just when you stop half way in the material. You have alot more control with D handle.
