windmill man said:Carvex Update
I have now had my re worked Carvex back for about 10 days and have given it a very thorough shake down before posting back here.
I received it back from Germany with a letter of explanation as to the cause of the problems and a list of the parts that have been replaced or upgraded.
The guy who became involved, to sort it out, holds a very senior post in Festool Germany and over saw the whole process of the reworks, modifications and upgrades. He states in the report that he did the final QC and test cuts and that the operation my Carvex now is to his standards and expectations. I thought my standards and expectations were high but they are dwarfed by his.
The thing is amazing; I even checked the serial numbers and the work blemishes as I could not believe it was the same saw. It s cut and operation is remarkable and beyond anything I thought a jigsaw was capable of producing.
I have just about done everything and anything you can do with a jigsaw over the last few days and cut every material I could think of . In every case the Carvex performed above and beyond my expectations.
Some here will say what is the point of this post, well it's simple.
If you own a Carvex and are having problem with it, e.g.
Blade jumps out of the v guide.
It is not cutting square.
The quality of the cut is poor.
You have any rotational movement in any of the bases.
You are burning and bluing blades more than normal
It will not follow a straight line.
It will not follow smoothly curves.
It will not follow on the guide rail or any other fence (i.e. Speed square or guide baton)
You cannot get near perfect circles using the attachment.
The dust port does not firmly attach to the bases and pulls out easily during use
The blades release over shoots the mechanism.
The above are problems know to Festool and they now have reworks to correct them.( By now this information should have been disseminated to the various national companies and service departments of the countries into which the Carvex is now being sold ) and you should return it for repair.
Just one more point, there has been posted on here a ?fix? for the Carvex, (removing and bending a spring) I would not do it . This item was not replaced and you may invalidate your warranty.
	joiner1970 said:I wonder if those carbide guides that were on the Trion have been scrapped for good reason. I have just been sent Bosch's new jigsaw the GST 150 CE to test out and give my opinion on, and the first thing I noticed was that they have also removed the carbide guides that they had on their other model. I seem to remember lots of people moaning about blades burning etc on both the Trion and the Bosch jigsaws.
By the way the Bosch is a very nice jigsaw
windmill man said:Evening JMB
If memory serves me right, The V guide plate is sprung loaded. The piece you removed in you video is the bit that gives it , its loading. That`s one reason I would no bug about with it. Above the V guide is a hardend steel nub.
The Carvex carries its blade slightly more forward than most Jigsaws. So as you cut the blade is not against this nub but is "supported" by the sprung loaded V guide. If you increase the cutting pressure the guide retreats and the blade rubs against the hardened nub . If you increase cutting pressure again it will start to blue the blade because of the friction. The nub is a lot harder than the blade. So wear should not be a problem.
John
windmill man said:Hi JMB
Think there is more to the design of the Carvex than meets the eye. The V guide is just a guide . ( In the trion it seems to act more like a lateral support)Think the spindle and how it works and its position in relationship to the guide is the key to its performance. I also think the way the blade locks into the spindle and how it is held also have a lot to do with it.
John
jmbfestool said:windmill man said:Hi JMB
John
How a blade is held is import like you said well the Maffel Jigsaw just rely on that welll held blade and nothing els! The advantage to that is you can turn the blade around and have if facing backwards so you can jigsaw backwards away from a wall so you can start closer to a wall.
Innovative CUmax sawblade clamping ensures a positive fit because of a wedge pushing against the blade. This design reliably fastens the sawblade so that it cannot be displaced.
[attachimg=#]
JMB
Brice Burrell said:joiner1970 said:I wonder if those carbide guides that were on the Trion have been scrapped for good reason. I have just been sent Bosch's new jigsaw the GST 150 CE to test out and give my opinion on, and the first thing I noticed was that they have also removed the carbide guides that they had on their other model. I seem to remember lots of people moaning about blades burning etc on both the Trion and the Bosch jigsaws.
Can you share your opinion of the Bosch here on the forum?
Michael_MA said:jmbfestool said:windmill man said:Hi JMB
John
[attachimg=#]
JMB
Well, the Mafell Jigsaw is also very nice from it's design and features..
besides, it's weight (2,5 Kg) and size, it requires special CUMax Sawblades, which are rarely to get on the market, except from mafell, because they have welded two saw blades together and nobody else does this..
The Shortcoming of this is the price - in Germany, 2 CUMax sawblades cost about 30 Euro, which is raughly 37 $..
In the German Woodworker forum, some colleagues told from the Fair in April, that the people at the booth of mafell showed their Jigsaw with 1 inch chipboard and ply telling the people near by, they should stand clear, as the saw blade could simply pop off during curve cutting.. and it did ! - nobody was hurt furtunatly..
Festool showed the Carvex first time with 40mm melamin lam?nated Kitchen tops and ply wood.. notheing fell of.. actually, there is also a video from the fair on youtube:
Festool Carvex on the German Woodworker Fair 2010
