John Stevens
- Jan 16, 2007
Okay, so festool sells some centrotec bits that include countersinks and depth stops. Sitting on the desk as I type this, I have two of them, nos. 492 523 and 492 524, new in the boxes.
The smaller drill bit is 3.5mm in diameter and the larger one is 4.5mm in diameter. My questions are:
1. Are these designed to go with any particular sizes or types of screws?
2. How would you use these if you were going to pre-drill holes to screw a 3/4" piece of wood to a 2 x 4, or vice versa? Normally, when I pre-drill a screw hole, I'll drill a narrow hole (narrow enough so the threads of the screw will grab firmly) through the top piece and then far enough into the bottom piece so that the screw will bottom out just beyond the depth of the hole. Then I switch to a larger bit and drill out the hole in the top piece so the screw can slide through without the threads engaging at all. Same process with these bits?
Thanks in advance for your help.
Regards,
John
Regards,
John
