Crazyraceguy
- Oct 16, 2015
This is the first of three essentially identical units. They are for each floor of the building, added in phases.
The next one won't happen until November.
It's a kind of unique look. It is rare to have the toe kick on both sides, though it's not much of an offset?
It's also not the usual employee side/ customer side with a countertop either. The "outside" actually goes near a window. Sadly, I spent a bunch of time making that outside mitered corner look perfect... and no one will ever see it on the 3rd floor. There is a column that separates the far right section, along with a waterfall drop to the ADA height.
It gets a narrow top, standing height, with tablets for checking in, thus all of the brush grommets.
It's also odd, in that the access panels are attached with locks, rather than screws. I have only done that a few times. Apparently, someone thinks it's better to need keys to access the chargers than a hex wrench?
The real beauty is that it has to go through a window, no elevator.
