Iwood75 said:Check out this thread. ---- "My new Kapex, thoughts so far"
Sorry I don't know how to make it a "link." Just use the search tool and you'll find it. Tom has a great solution... photos and all.
Peter Parfitt said:Thank you Bellchippy, the Bessey toggle clamps work well. But, if you cannot get these and need to improvise then...
If you take a piece of wood that has a rebate on the end, perhaps to half the thickness of the wood and maybe 10-20 mm in width. Position the rebate over the small piece of stock to be cut. Use either the clamp that comes with the Kapex or one of the MFT clamps to then push down on the rebated piece of wood which then holds the small piece in place. You may need to use a clamping piece on both sides. I am sorry not to have a photograph but I have done an awful sketch.
SRSemenza said:Peter Parfitt said:Thank you Bellchippy, the Bessey toggle clamps work well. But, if you cannot get these and need to improvise then...
I think you just need to be careful with that set up , that the end opposite the clamp doesn't lift.
Peter Parfitt said:SRSemenza said:Peter Parfitt said:Thank you Bellchippy, the Bessey toggle clamps work well. But, if you cannot get these and need to improvise then...
I agree and so one needs to judge whether to have the clamping on both sides.
Peter Parfitt said:One could always super glue to wood in place [wink]
