Gordon Bombay
- Apr 3, 2015
I have a built in project that I am working on with longer panels (2432 mm). I have a 1400 holy rail and would prefer not to buy another (and also avoid buying the connection rods). The only real concern that I have is clamping mid-panel. Is it safe to use the quick clamp or screw clamp on the actual guide rails themselves (basically using the quick clamp or screw clamp to clamp down the rail like a piece of wood)? Or do others have suggestions for avoiding purchasing two rails?
If not, it seems that I could use the indexing rods and keep them attached while doing the routing (and move them to before or after the router as needed).
