Alex said:
Qwas said:
I'm not familiar with the term "teeth per minute" in woodworking. I don't think I've ever seen it used to compare saws. I think in this scenario it is giving false information.
Wouldn't the blade diameter (along with rpm) play a critical role in the cut quality?
Then you haven't been paying attention. It is common knowledge that blades with more teeth give better cut quality. In this regard "teeth per minute" is a decisive factor. It works just like "grits" with sandpaper. The smaller the increment in the cut, the better the quality of the cut.
To look at the blade diameter or RPM as factors all by themselves don't make us any wiser, because the only thing that really matters regarding these two factors, is the resulting speed with which the teeth hit the wood. The speed of the teeth is determined by combining three variables: RPM, diameter and number of teeth.
Question: what is it that defines a cut as being of "good quality"?
WRONG You don't know what you are talking about.
you go ahead and put a 100 tooth blade on the fastest most powerful saw motor you can find and plunge it into 8/4 Hard Maple and start ripping... I'll take a 10" 18 tooth Thick Stock Rip Blade, which has the correct tooth design, depth of gullet and hook angle.
you will likely start a fire, while my blade will make clean cuts even on a crappy plastic jobsite saw.
the blade DESIGN makes all the difference in the world.
granted, there are "in between" compromised designs such as the "general purpose" or "Combination" blades we often receive complimentary with new tools,
but these don't do anything exceptionally well. (Jack of all trades, Master of none!)
use the right blade for the job at hand and you will be very happy with either Festool saw you choose.
as has been said here a few times, the TS55 is lighter, while the TS75 has greater depth and more power (of course it takes more power to spin a larger blade!)
Personally, I would like to be able to use TS55 blades on my TS75, the the added power of the TS75 could be fully appreciated when comparing the two saws, eh?
There is a plethora of knowledge available when it comes to saw blade design and theory... but merely calculating the rim speed times the number of teeth... -that equation is missing a lot of other variables!
