CMS router table fence improvements ( micro adjust using crown stop) "updated"
[member=44099]Cheese[/member], I'm still thinking that I'll park the DRO on top of my On/Off switch.  [member=11629]GarryMartin[/member], you can see how the sliding table rail negates the ability to use that bracket on the CMS-GE.
I like what you did for the On/Off switch. Once a RH extension table is added or if the sliding table is added, access to the original Festool switch is pretty tough, that could be dangerous.  [tongue]
[member=44099]Cheese[/member], that was one of the most compelling drivers for me to remove the stock 15 amp switch and go to the 20 amp switch above the deck of the CMS.  Couldn't see having my mugly ugg down next to the place where sharp tools were spinning faster than I can run, especially while oozing bodily fluids necessary to support human life.  [scared]  We won't mention the other compelling reason to go to the 20 amp switch.  [wink]
I see what you mean - you've lost the profile on the front of the CMS-GE because of the added infeed table. Gotcha.
Hi everyone. I'd like to make this adapter but it looks like woodpeckers discontinued the Micro Adjust. Any suggestions on alternatives still on the market?
That's unfortunate, it functions very well with a minimal amount of backlash, from .001"-.0015". Because of the functionality and the broad based use of this adjuster, maybe Woodpeckers will bring it back as a special offering as a OTT tool? @jeffinsgf ?
Not a long term solution, but for the present, I would call WP Customer Service. There might be a few still on the shelf. We rolled it into our new fence design.
Will give that a try, thanks. Would you say the new WP fence design is compatible with the CMS router table?
