A
Administrator_JSVN
Guest
copcarcollector said:Thanks! Nice car.
Yes, if I could afford one. [huh] Pic is from the Porsche museum in Stuttgart. 50th anniversary of the 911.
Shane Holland said:Cordless Carvex 420 hits the ground in the U.S. and Canada on December 1st.
There will be a Basic version which does not have the batteries or charger for those who already own a Festool cordless drill. Also available December 1st. The basic version of the Carvex does not have a space for a drill in the Systainer.
GPowers said:Shane Holland said:Cordless Carvex 420 hits the ground in the U.S. and Canada on December 1st.
Will the 14 volt battery from the C15, work on the cordless Carvex?
EdSweeney said:Has Festool announced a specific date for the battery Carvex?
UK Jonathan said:Hello to everyone on the forum.
I'd just like to offer my experience of the 420 jigsaw, it's been available for quite a while in the UK and on the whole is very good. In use, the saw shows hardly any vibration, it will happily sit on it's own with the motor running and stay put. The saw also has plenty of power for all cuts and all materials. One of the noticable things over other jigsaws has to be the weight, When you first use it, you can't believe how light it is. The only small gripe with it for me is the two side switches to start the saw. They are not in the best of places, I have the 'D' handle and it would have been so much better if the switches had been in a more comfortable position to access. I've read in this thread somewhere that the light can be turned on or off but the light is on all the time the saw is running. One more thing to add is the extraction, Brilliant, takes 99% of dust away.
Jonathan.
UK Jonathan said:Thanks for pointing that out to me Frank. As a rule, I alway's read in depth the owners manuals that come with the tools but thought that everything was going to be so straight forward with the jigsaw, I never bothered! I will have a read tomorrow. I'm guessing it goes something like: pull the trigger twice, unplug the tool, turn it upside down, knock on the base four times and turn the speed dial to number 4, then the light comes on and you have to do the same in reverse to turn it off.
Jon.
BeardMan said:
BeardMan said:Is it possible to cut a perfectly square a 4x4 with Carvex 420?
