Conturo and Vac Buying Advice: Best vs. Avg Choices
leftistelf
I have a library of white melamine bookshelves to produce. So, I've decided that the Conturo is joining the team. And why not as the vac, too?
Could I please solicit your opinions on the following purchase opinions I have:
[list type=decimal]
[*]It appears the Conturo Set is the the good buy
[*]i already own the mfk700, but not the "b" base with brake. Is it worth getting the "b" base? If so, what item number is it?
[*]i own the 1, 2, and 3mm radius bits. Which bit is best?
[*]Which banding has worked best for you? I need white.
[*]I think the white glue should be used with white banding.
[*]The Vac-SYS is a luxury,  but if I'm going to buy it why not get the system set with both modules (201065)? My shelves are 4' long, so I think it will brace better, right?
[*]Which sustainer do you store the Vac Sys System Set in?
[*]Do I need two MFT clamps (494977), one for each head? @$250 each, I don't want to buy an extra if it's unnecessary.
[/list]
Thanks!
