Hi!
I've purchase a used edge bander.
It started good for the first few edges, I'm using 1mm pvc.
Then the machine failed to roll the edge out.; I have to give a litte push with my hand to help, after that I can apply the edge.
The feeder works, it loads the edge and also the rollers are working when I press teh start button.
I did not see anyhing in the way.
I'm not sure what is causing the problem.
Appriciate any help with the issue.
Thanks,
Thanks,
