semenza
Yes, the Cover Plate does close off the hole in the blade shroud with no provision to preserve air flow. So I don't know about that airflow design. Regardless of the airflow the DC is better with the plate than with out. So it must be getting enough with the hole covered anyway.
On the TS55 the d36 hose does seem better but I would not say it is markedly better. I don't think I ever tried the d36 hose with out the cover plate so that may give a differing result. I do not think the d36 improves DC enough to justify getting the d36 just for the TS55 saw.
I could see the possibility of the D36 hose making more of an improvement on the TS75 than the 55 because the increased airflow of the d36 may work better in conjunction with the larger (because its longer) opening in the 75s blade shroud.
