CSC SYS 50 alignement sliding table
Xere
Hi Guys,
I am reading you for long time although I am based in France I love your forum and the quality of the exchange.
Therefore I decided to contribute with a question I have regarding my last acquisition the cordless table saw CSC SYS50
First of all I want to tell you that I was impressed about this tool, this is for me clearly SciFi tool as it is fantastically made.
I start play with it and really enjoy.
The only point I notice is regarding the angle calibration of the blade. I have been following the manual and calibrate with square at the right of the blade and fine. Then I start checking with the square placed on the sliding table and discover a small difference. I then check alignement between table and sliding table and sounds like they are not perfectly aligned.
I was wondering if any of you know if it is normal or how I can adjust this to get perfect alignement between blade, table and sliding table.
Hope you will be able to support.
Thanks guys
https://ibb.co/WcBMqsrhttps://ibb.co/BZ8kprLhttps://ibb.co/QDrF8qQhttps://ibb.co/6ByCHN9
Thanks for your comment, I checked and this is not the case, I intently took this picture showing the angle left right of the sliding table. Maybe not the best way to show this issue
woodferret said:
One of your pics has daylight underneath the sliding table.  Is it not flat or is table lower than the fixed bed?
