- Oct 8, 2007
Here is a idea I came up with to help with the constant changing of cords and hoses.
I have several tools that I use on a daily basis . To speed up work I built a blast gate box that each tool has its own power and vac to. All I have to do is open the gate and turn on the tool. This greatly reduces the wear and tear as well as extra time pluging and unplugging tools pwr and vac lines.
Each tool has about 35' of hose/pwr to it so it can be used anywhere in the shop. All tools plug into a power strip and it plugs into the ct 33 so all the tools trigger the vac. I added a air adapter as well so air tools will turn on the vac too.
the box is made out of mdf and the gates of corian,thou you could use mdf or acrylic as well.
the box has a vacuum gauge which helps let me know when the bag is getting full as well as performance monitoring.
There is a extra port with pwr and vac hose for those tools that need to be changed as needed.
the box is connected to the ct with a 50mm 2.5m vac hose to reduce restrictions and the box is mounted on a 2''emt boom arm like post high enough to allow opening and emptying the ct's bag when full.
[attachimg=2]
Bill In seattle
[attachimg=2]
Bill In seattle
