TheTrooper
- Mar 19, 2015
After 9 years of constant use my Rigid vacuum has passed away and ive been using my CT36. I do hardwood floors and tile. Normal day is scrape the floor with a 4" razor blade, cut door jambs and baseboards, sand the joints of subfloors or grind high spots in concrete. If the floor is flat and doesn't need leveling I will vacuum the floor 3 times to get all of the dirt, drywall dust and so on out of the pours of the floor plus anything that could be under the baseboards. The Rigid had a Clean Stream filter in it and they last about a year or two. Once it would get clogged, I would tap it on the dumpster at the site and i was good to go.
So here is my question. Should I be using the white bags or the plastic and just use the auto clean function and just tap the filter off when I dump the machine? The other thing I'm considering is purchasing a mini or midi to save space in my truck.
