jonny round boy said:
To clarify, I have a CT Mini which is used primarily for the Kapex, and it's stored right next to the Kapex. With the hose coming out of the top, it's more than long enough, but it would NOT be long enough to go into the front of my CT26 if that were in the same position.
What he said abou the CTs.
I made my Kapex hose about 4.5 feet. It is long enough to use with CT Mini / Kapex MFT combination. The CT goes right under the MFT Kapex with the hose going straight up at the back edge of the table. This is
just long enough with the CT in the right spot. Doing it over I would have made it 5 feet long to allow a little more freedom of positioning for the CT. I also bought two rotating connectors (vac end ) along with a hose to hose connector and made the extra seven feet into an extension hose to use with a D27 or D36 for shop clean up or just to reach farther to a tool if needed.
Dan, are you making a Kapex hose or something else?
